Hi Rob,
What is a "schp" ?
Message: 10067 |
Date: 8/30/2014 |
Subject: Re: Pwm and logic levels |
Sorry for that. Thanks for asking.
It is the abbreviation for safety charge pump. Rob
Hi Rob,
What is a "schp" ?
Message: 10099 |
Date: 9/2/2014 |
Here is a bit better of a question.
How would you go about gaining control over turning the below program on and off with a bit?
The below program is working for me now, but I just cannot gain io control over it
I will be also implementing externalbuttons.c , so I am thinking estop function in this program might help me get there easier. Use estop function in this program to also stop the stepaspwm.c from stepping.
// Example showing how any of the 8 Step and Direction
// frequency generators may be used as a PWM
//STEP_RATE_ADD 0x3c - write a 32 bit word - Bit31=enable, Bit27=Drive, Bits24-26=chan, 0-23= signed fraction of 16.666MHz
//STEP_PULSE_LENGTH_ADD 0x06 - write a 6 bit word - 0-63 = # of 16.666MHz clocks to this address
#define CLOCK 16.6666e6
double DutyCycle, Period;
int Frequency;
int Pulse=50; // Fixed pulse length of 50/16.66MHz = 2us
int StepChan = 4; // KFLOP Step Gen 4 IO10 Pin 36 - when high(1), this turns on the C4 Safety Charge pump for supermax
SetBitDirection(36,1);
FPGA(STEP_PULSE_LENGTH_ADD) = Pulse;
DutyCycle= 0.33; // Note Duty Cycle can't be zero (useful range 0.02 - 0.98)
Period = Pulse/DutyCycle;
Frequency = (int)(0x7FFFFF/Period);
printf("DutyCycle=%f, Pulse=%d clocks, Period=%f clocks\n",DutyCycle,Pulse,Period);
FPGA(STEP_RATE_ADD+0) = Frequency; // put 23 bit frequency
FPGA(STEP_RATE_ADD+1) = Frequency>>8;
FPGA(STEP_RATE_ADD+2) = Frequency>>16;
FPGA(STEP_RATE_ADD+3) = 0x88 + StepChan; // combine enable, Drive High and low mode, channel
Thanks Tom!!
Rob
Message: 10101 |
Date: 9/2/2014 |
Hi Rob,
See attached program. As long as ServiceChargePump() is being called (add to a forever loop in your Initialization Program) then turning on and off IO Bit 46 (KFLOP LED) should activate and deactivate the charge pump.
Please attach C files to post in the future otherwise the formatting gets messed up in the email.
HTH Regards TK
Message: 10102 |
Date: 9/2/2014 |
Subject: Re: Pwm and logic levels [1 Attachment] |
Thanks Tom,
I'll give it a go and see what happens (with my lack of c knowledge and abundance of curiosity/drive to get this done)
I'll attach files next time. Unfortunately most of my posts are on my phone... Ya, that looks terrible.
Thanks so much for being so patient and your help!
Rob
Hi Rob,
HTH Regards TK
Message: 10150 |
Date: 9/8/2014 |
This file works great for my charge pump. I can control it now. Thanks.
Currently it is pulsing appropriately and turning the pump on and allowing me to enable my system. The logic level is low though (on my logic probe and a voltage of .80vdc)
Would it be possible to get a pulse and a logic level of high with adjustments to this c file?
Thank you,
Rob
Hi Rob,
HTH Regards TK
Message: 10151 |
Date: 9/8/2014 |
Hi Rob,
I suppose you read 0.8V because we are programming a duty cycle of 33%. So an output of ~2.4V x 33% would be 0.8V on average.
You might change the duty cycle to 50% instead but basically I think it should work ok.
But actually the pulse length and polarity is a global thing. I believe you have Step and Direction Drives so that should be the primary thing that determines the setting. Remove this line so that the FPGA
pulse length is only set in your Initialization Program and not changed by this charge pump code.
Whatever the Pulse length number is set to in the initialization program set the same value in this line so it computes the
right frequency to get the specified duty cycle:
Pulse=50
From: "Rjreese29 rjreese29@... [DynoMotion]" <DynoMotion@yahoogroups.com> To: "DynoMotion@yahoogroups.com" <DynoMotion@yahoogroups.com> Sent: Monday, September 8, 2014 4:52 PM Subject: Re: [DynoMotion] Re: Pwm and logic levels
Thank you,
Rob
Hi Rob,
HTH Regards TK
int Frequency;
Thanks Tom!!
Rob
